The ultimate race suspension geometry component. Made in England!
After months of development. testing and manufacturing. We are proud to announce that the most difficult product we’ve ever made, is now in stock! ๐
Driftworks GeoMaster – Race Hub Knuckles
What are these?
These are custom made Hub Knuckles with completely new geometry settings.
You will receive a set of 4 Hub Knuckles with Polyurethane bushes included.
What will they do for me?
Roll Centre Correction:
Fitting the Driftworks Geo Master Knuckles lowers the car by 45mm front, and 50mm rear without changing shock length, alignment arm angle, or track rod angle (the cause of bump steer). This corrected roll centre means that lowering your car no longer ruins the ‘in travel’ alignment. Handling benefits are night and day compared to your normal ‘slammed’ track car, and specifically traction is notably improved over a traditionally lowered car, as proven by the Driftworks S15 Silvia, that has 666bhp, and using geomaster knuckles can struggle to break traction at times.
Huge Steering Angle! Although these hubs are just as suitable for a track car as a drift car, when fitting them to a drift car they do have the added benefit of increasing your potential steering lock dramatically once you modify or remove your bump stops. Again using the Driftworks S15 as an example, this car doesn’t even have steering rack spacers and is capable of backwards entrys.
Quick Rack? No need!ย These hubs give you quicker steering.
Check them out in the webshop here: Driftworks GeoMaster – Race Hub Knuckles
These look the nuts and cant wait to get myself a set ๐
omg, this is everything i ever dreamed off… can i swap it for a nice blonde dutch girl?
Dunno maybe, send photo’s and don’t tell Mel ๐
Look the biz!!! Nice job, Well done.
