09 GT Bump BMX
for sale GT bump bmx, have no use for it and need to save for new car so has to go.
GT Bump BMX Bike 2009 - Full Spec
• Frame : GT dirt/street design, 100% cr-mo, machined cr-mo headtube for integrated headset, "MID SIZE" BB shell, small cr-mo 5mmT. Dropouts, seat stay mounted U-brake
• Fork : GT dirt/street design, full cr-mo, small dropouts,1-1/8" x 22.2mm steerer, 1-1/4" O.D. blades
• Chainset : Improved GT tubular Cr-Mo 3pc., 8 spline, double bolt clamping, '08 GT 33T CNC aluminum W/cut-out windows for lighter weight
• Bottom Bracket : Sealed bearing "MID SIZE" BB set, cr-mo 8 spline axle
• Pedals : GT Dirt/Street platform design, aluminum body, press-in pins, cr-mo alxe
• Cassette/Freewheel : 12T cassette
• Headset: TH No. 8-D, Impact, Campy 1-1/8" integrated design,
• Chain : GT branded, cartridge sealed bearings, 3/8" cr-mo axle, 32 hole
• Front Hub : Joy Tech cassette, 4 cartridge sealed bearings, 14mm cr-mo axle, 36 hole
• Rear Hub : Joy Tech cassette, 4 cartridge sealed bearings, 14mm cr-mo axle, 36 hole
• Rims : Alienation Black Sheep, double wall, black 32 hole front, CP 36 hole rear, 33mm width
• Nipples : Brass
• Tyres : Front: Kenda K-Rad 2.125" 65psi, Rear: Kenda Kiniption 2.1" 120psi
• Seat Clamp : GT CNC mini design
• Front Brake : Alloy side-pull caliper
• Rear Brake : Tektro, FX-15D, linear spring, single anchor bolts, cold forged aluminum U-brake
• Brake Levers : Tektro, 275A, aluminum, hinged clamp
• Handlebar : GT dirt/street dual radius bend, Cr-mo, 7.67" rise
• Stem : GT FS design, cold forged aluminum, machined GT logo
• Grips : White old school mushroom grips
• Saddle : Blank white/black
• Seat Post : Aluminum double bolt micro adjust
nice little bmz, 250 notes when new, forks crank arms and bars painted different as not keen on the daft gt logos everywhere lol
looking for £100 ono collected from newcastle
chees for looking, andy
