For Sale 1JZ/2JZ ABC Adapter Kit & Tilton Clutch
Selling my JZ ABC Adapter Kit & Tilton 7.25" Triple Plate Clutch which Adapts 1JZ & 2JZ to: E46 M3, E36 M3, E46 320/330D, E39 525/530D, can also be used with E60 diesel boxes but clutch plates will need replacing due to the different spline.
The entire setup was in my Altezza and worked sweet. It's rated to 1500NM.
Comes with:
One-piece flywheel
ABC Adapter plate (the newer style where the starter clears the plate nicely)
Billet release bearing
All Bolts required
ARP Flywheel bolts (Been used once, would probably buy new but some say you can use these twice)
£1800
If required (at extra cost):
E46 M3 smg gearbox, which ran absolutely fine, went into all gears perfectly, but I did notice some noise which could purely be due to the single mass flywheel, but I'm unsure so gonna price it low. It's also had the bell housing welded: £500, will come with hack engineering billet pin, retaining clip, clutch fork and cut to length guide.
Coolerworx PRO Shifter: £280 (black)
2JZ Starter: £80
Custom prop made by Prop services Heathrow to suit IS200/IS300/Altezza (might work on JZX unsure of length): £180
Brand new BMW Slave, brand new master to suit (0.725) & braided clutch line: £100
Gearbox mount with Strongflex mounts: £150
Can post everything internationally but the gearbox.
Perfect for JZ IS200/Altezza or JZX manual swap, just please check if the prop will work on your car.
Also happy to do a price for the entire package.
Yo,
Do you know where to get a replacement clutch release bearing? I have the same kit, and the tilton release bearing doesn't work with the E39 530d
