1st time build ca18det
TankTurbo
Hi Everyone
My s13 ca18det project is well on its way however I need your advice
NB: This is my 1st build
I have purchased the following already:
K1 forged conrods – came with ARP 2000 rod bolts
CP 84mm forged pistons
CP piston ring set
CP XT gudgeon pins
MLS complete gasket set
ACL main ends and big ends racing bearing set
Stainless steel sump nuts
1x 2nd block
1x 2nd hand crankshaft
Oil pump
Water pump
What further components do you recommend I purchase to make my sub assembly more reliable?
Eg the bolts and brackets that hold the crank in place
Maybe a crank pulley or even a harmonic balancer
I would rather spend more time and money on the project and eliminate any part that could cause failure in the future.
Also what engineering recommendations do you have?
Many thanks in advance
