200sx S14a subframe bushes
UrbanRacer
Hi,
The bushes on the rear subframe of my S14a are shagged, i had a look at the shop and you have driftworks ones but the description leads me to believe they give a harsher ride quality than the stock items, if so how much? also do they transmit a lot of road noise or diff noise?
The reason i'm asking is my car is used for day to day use.
Polybushes will transmit MORE noise but it's all relative. If you polybush every single item on your car, have a worn diff, worn wheel bearings and drive down poorly surface roads on 19" wheels with super low profile tyres then yes, it might be an issue for you.
However, if your car has a healthy drivetrain, the reality is you're unlikely to notice except perhaps for over rumble strips and the like, but the difference in overall taughtness will be massive. The main subframe bushes are one of the most important ones to replace, and I'd always recommend at least a polybush. :)
