Hey guys
i thought i will look for "help" here.
i am in the process to pick up a 02 GE VVTI from a 02 GS300.
Complete Engine+ harness and ECU
I am very experienced on the LS plattform as well as SBC and BigBlocks
so building engines is nothing new.
however i am bored and i was always a fan of the 2jz platform.
Yes i selected the "worst" 2jz a GE VVTI, but i think i can make it work for what i am trying to do.
I have a 96 Chevy S10 sitting here that could be a cool , road racer build with a manual trans.
THIS IS A BUDGET BUILD and i dont mind ebay /Amazon as a parts provider if the parts are decent.
so lets start the Q's:
What MANUAL 5- speed Trans is the best Budget option and can hold up to 600ish HP ( crank)
and has "reasonable" adopting parts for the 2jz?
BMW trans, T56s, CD009s etc? what are you guys using?
Engine:
i will not touch the cams.
however is a ADJUSTABLE CAM GEAR worth it on the exhaust side for the VVTI engine?
how much degree of the advance or retard , makes sense ?
Turbos: what size is efficent for a 2JZ ? i am used to V8 turbos and would spec to big i assume.
However i have a BRAND NEW GT3582r T4, ar.82 on the shelf that i would like to use if its efficent ?
what other Ebay turbo options do well?
Air Intake: I saw the ebay Whale Intakes and the simple 100$ intake tubes ( wher i still dont know how you would be able to reach the bolts inside of them, lol
Turbo manifolds: there is a lot of ebay budeget options, which one has proven good?
Do SUPRA manifolds fit on GE VVTI? i doubt it?
Where do you drill the Turbo OIL SUPPLY?
Where do you drain it back ? oil pan? side?
Engine Management
i found that the EMU BLACK seems to be a good choice, but since i have no idea of it i saw that some guys mod and use a holley terminator X, which would be right up my alley since i know it.
What part # Headgasket to use?
Are there Ebay Head Studs that make sense?
New Oil pump or is there a mod i can do to the OEM pump, like porting , shimming etc?
Any easy but effective Valve train mods i should look into?
thanks for looking at this
Engine:
Engine Management
