2jzge ecu issues
2jzjzx
Hello,
Ive got a 2jzge swapped jzx81 and Im having issues with the ecu. When I plug in the ecu It always overheats and catches on fire. The pins that catch on fire are for the chassis ground and the vvti solenoid. I dont know how the grounds are causing what I think is the diode to explode. When I plug in the ecu and put battery power too it, those pins always catch fire and wreaks the motherboard. Im wondering if anyone has experienced a problem like this (probably not cause its probably something with my wiring) and if so what can I do to fix this problem so I dont brick the next ecu.
Hopefully there are wiring gurus out there that are able to help me out.
Thanks
