2xVolk Racing SF Challenge 18x9
FC3Sleo
as above in sliver 45mm offset, with 245/40/18 gridII tires, good tread but slight worn on the inside. offers. pics to follow
Zenki Silvia said:
PCD?
better they'r gay common as fook 5x 144.3 :(
you mean 5X114.3...
also worth bearing in mind that with that offset and size they are most likley fronts from an RX7 (or MR2) which means oversized centre bore on nissan fitments (MR2 bore is too small) - ie. centre badly if you do your nuts up wrong and will tend to shake loose. you can get new centre bore spiggot rings for around £20 which will sort it tho :) will need decent spacers to sit right on nissans :nod:
-THE Volk Racing wheels- :
Nice rims. must be worth is especially with the tyres. You boys will drift on big expensive tyres tho :rolleyes: shame I'm still running old skool 4 stud!
:D
mittomatto said:
you mean 5X114.3...
yeah sorry typed too fast.
sly, james :)
if there the ones you won off ebay i know what you paid for them, i will pay a bit more than that if you are interested but not that much :)
