300zx Track Rods
FireStorm999
Active Member
Do you guys stock these?
im using the DW offset rack spacers with tein s13/s14 rods and both wheels are toeing in, so they got put back in the box.
my options are to cut down or use z32 rods.
could you guys swap if thats the case?
previously returned teins that couldnt be warrented due to a little bit of rust. :(
Morning,
We don't stock 300zx ones I'm afraid.
I take it you have adjusted the toe?
What car is it?
Cheers, Kam.
Morning,
What car is it?
Cheers, Kam.
yes its adjusted to the max
the tien ends wont go onto the rods anymore and both wheels are still toing in.
to save me cutting/adding extra threads and ruining some tein rods i was going to use z32 as they are shorter.
its for a PS13 with a S14a steering rack
Ah ok, you'll need to cut the rods down or run s14 bottom arms :)
I'd do the latter, get you some extra gains.
Thats not the case, they were on our s14 test car no problems, likewise with hundreds of customers.
As usual, they are a custom race part, changes might need to be made :)
did you use them with tein rods and tein ends???
with a S14a steering rack S14 lower arms, 5 stud hubs, tein rods and ends adjusted wound on to the max with the offset rack spacers both of my wheels toe in by about 10 degrees.
i dont mind cutting, just wondered if tein did a z32 rod, as that would solve the problem and still leave me with an item that i could sell later if i broke the car one day.
