Mines pretty nice to drift, no lock mods usual mods (although the ECU apparently cancels anything gained)
Coilovers and locked diff.
Nothing like a boat, I had a V8 Soarer before this (even that drifted very well, nice and elegant) to compare it to the Soarer though it transitions a shit load faster.
I do have some offset spacers to fit but I havent got round to fitting them yet. I do feel the extra lock is needed, but as standard not too bad.
Power wise as standard is fine.
I did struggle with 235s, but those where the last tyres I had on that day - it being a blistering hot day probably made it that much more hard work. 225s are fine. I am using 18s to drift on so maybe dropping to 17s will help, dont know.
Welded diff on a day to day basis on the Z for me is a pain in the arse, Ive had welded diffs on lots of other cars but on the Z its crazy. Not sure whether its the combination of a single mass flywheel, carbon fire propshaft, grippy rear tyres, shorter wheel base but you dont just get the skipping of wheels you get a load of chattering from the gearbox.
Day to day, normal diff. Drift day, welded.
I keep getting told Im daft for drifting a 350z, nice car, expensive, blah blah. Ignore them and get it drifted, unless its your very first drifter, then thats probably not such a good idea.
I used to have an s13 and Ive probably got less money in the Z than I did in the S13, including costs of cars and parts. The S13 cost me £500 to buy!
