350z rear hub bushes
HmmBen
I'm after a set of 350z rear shock/damper bushes that go in the hubs.
I can't quite make out which of the Hardrace ones I need or whether they are proper press in bushes or multi piece poly ones which I would prefer (for ease of fitting)
Any help to clear this up would be appreciated
Thanks
I believe so. I was hoping to know if they were multi piece or not as I'm trying not to remove the hub and use a press. But I don't think I'm going to be that lucky.
I will order a set from you either way.
Thanks
