Been drifting my 350z for a few years with poweredbymax steering angle kit. Running the rear sway bar loose. Front sway bar in the middle setting. 0 rear camber close to 0 toe some toe in the rear. 9degrees caster in the front and -3.8 camber in front and small toe out in front. Initiating high speed drifts the car will undeersteer hard and won't turn into the drift at random times and seems to be getting worse. Tires are 265 35 18 achilles atr sport 2s. And Bc Coilovers
