5 stud hubs
Dan H
Have you got one of your front and rear 5 stud hub conversions, new rear bearings, and braided brake hoses to fit z32 alloy 4 pot calipers to a s13 in stock?
Hi Dan, we're currently out of stock of the hub kits, we're waiting to hear back from our manufacturers on a due date for the next batch, but it could be anywhere between 2 and 6 weeks before we recieve them.. We've got a few of the brake hoses in stock.
Phil :)
Seeing as I can't spend money on the hubs, how much could you do a package of DW value bits including:
camber arms,
toe rods,
traction rods,
poly subframe bushes,
lower arm poly bushes,
and a whiteline anti-roll bar kit
plus anything else I may need while I overhaul my rear subframe :D
Thanks.
Got my bits this morning thanks :thumbs: .
I can't figure out what 2 of the bushes are for though :confused:
They are rubber with a metal sleeve in the middle(14mm i/d, 23mm o/d, 57mm long), and an outer metal sleeve (39mmi/d, 45mm o/d 25mm long) and they have also got red circlips on the ends, and white clips next to the outer metal part. One of them is in a bag marked AEM 4035.
They were in the bottom of the Whiteline box that was open at the top, not in the jiffy bag with all the other bits.
Do you know what they're for, or has the citylink guy popped in a free gift :wack:
Glad you got it okay :thumbs:
We've had the whiteline boxes open to check that all the fitting kits are inside as they have a tendancy to lose bits before they even get to us :rolleyes: so although I'm not sure what it is your describing :wack: it could very well be something off our shelves.. If it's convenient, can you stick it in the post to us? :)
Driftworks Ltd
Storage Corporation House
Warstock Road
Kings Heath
B14 4RW
Cheers :thumbs:
Phil
