Martin Ffrench
Mitsubishi Evo Engined 4WD Colt 1995
Engine :
2 Litre Mitsubishi DOHC 16v Turbo Engine (galant vr4 better than evo 123)
Reprofiled Cams
Uprated Lifters
Evo 6 Pistons
T05H 20G Turbo
Rally Nylon Engine Mounts
Front Mount Oil Cooler
also has new water pump and belts and tensioers fitted.
Transmission :
Evo 3 RS Gearbox
Evo 3 RS Transfer Box
Evo 3 RS Rear Diff
clutch is helix i think have to check as new done no miles custom made to fit smaller mivec flywheel and take evo power.
Wheels :
Rays Engineering Gram Lights S57C 16s 4 x 114 pcd
come with the nuts.
ecu:
std evo 3
shell:
95 1.3 shell converted to 4wd all evo 3 running gear subframes hubs brakes etc. Has standard interior apart from 2 tenzo r red recliners. Has evo fuel tank uprated fuel pump. also. 95 on a plate and i have the book there.
It has an aftermarket intercooler with custom hard piping and intake pipe.
cage 6 point dash doger
and any other bits you see in the pictures are there. just ask.
0035385 7809132 or ffrenchm@gmail.com
must sell even if i really want to keep it 3500 euro takes the lot away. Can be made cheaper without cage etc. or will break if enough interest.
Engine :
Reprofiled Cams
Uprated Lifters
Evo 6 Pistons
T05H 20G Turbo
Transmission :
Evo 3 RS Gearbox
Evo 3 RS Rear Diff
Wheels :
come with the nuts.
ecu:
std evo 3
shell:
