Adjusting camber on a S15?
daniel83
Hallo!
My name is Daniel and I´m living in Sweden.
I have a Nissan Silvia S15 Spec-R.
The problem is that my tires are very mutch unevan wear on them.
Both front and rear.
How do I fix it? What parts do I need for that?
Many Thanks!
Daniel
Hi, Its unlikely to be camber causing it unless you are track driving hard. It most likely the tracking needs setting up. Any tyre/garage type place will do it for you and it isn't expensive.
I have lowering springs fitted on my car.
But I´m not sure if they did a wheel aligament on the car after that.
All the things was already fitted when I bought the car.
That´s why I suspect the camber.
