Advice need on wheel size to fill my arches
Nicky_S14a
Hi guys, I'm fitting a set of srbpower +50mm rear over fenders to my 2000 nissan s14a and im looking to fit a set of 18" rota grid drift's to it. I've got to the stage where I need one of the rear wheels to finish off the arches. Coilovers and a set of your alignment arms will be fitted to it too if this helps!
How wide and what offset could I go for in these rear wheels and would I need spacers? I'd like to go 10" if possible and would I need spacers?
Thanks nicky
Hello mate. The grids are available in 10x18 on an ET15. You'll definitely need to run spacers though to fill 50mm rear over fenders. If you think you can get a 9.5 or potentially a 10 inch wide wheel under a standard 14a rear arch with a roll/flare of the arch. Your adding another 50mm to that arch.
Spacers are available here :) Nissan 5x114 PCD bolt on wheel spacers 15 - 55mm - Wheel Spacers - Wheels & Accessories - Car Parts
What size spacer depends on your tyre size, alignment specs, ride height etc. I think you'll need at least a 30mm spacer.
