AE86 LSD (modified with uprated plates and other work)
Mr Doricar
JDM Loose yo
Selling on behalf of a friend.
AE86 LSD in casing, with crownwheel and pinion. Ready to fit into a early AE86 axle. As far as we can tell the diff is a 2way and has had machining done to it. It's got thicker plates for more lock, improved ramp angle and a few other trick bits. It's supposed to be a beast and perfect for drifting.
£300
Hi Matt,
Yes this diff would be awesome in the orange car. I found the diff to not be perfect. When I first got the diff thats currently in the orange car it would only spin one wheel and I had to change the oil and do lots of donuts to make it work properly. The diff in the ad should be amazing.
James
Diff in it now is just a standard Toyota one. Yep got the gasket. We need to arrange a time to get the door from Julians too. Are you going to the show?
I see you have a complete diff for a coupe for sale would u consider breaking it as i am desperately after a crown wheel an pinion for my motor.
Or would u know where i could get hold of a crown wheel & pinion?
I'm fairly sure Toyota can still get them but if not you could try a Techno Pro Spirit one. They seem pretty good and you have a choice of gear ratios.
