Apexi SAFC
TaxiDori
BEER CLINCH
Bought but changed plans so i will most likely need full engine management instead.
good nick, with instructions and wiring.
£70 + postage.
dont want to sound stupid sayin this but does this safc regulate the air and fuel ratio or am i mixing it wit something else. how easy is it to install. :D
yes, the SAFC is a fairly simple way of controlling bigger injectors or air flow meter and adjusting the fueling to suit.
It's not too hard to install, There aren't many wires to hook up, but you do need to splice into your ECU wires.
tell me what stage 2 means and I'll tell you if you need it :p
stage1, 2, 3 etc of tuning are totally different depending on which tuner or person's advise you're following, so don't really mean much....
oooh soz m8. well ive got t28 bb 5psi at da mo , bosch fuel pump, nd chip to be changed for jezz stage 2 runnin 15 psi, Pace intercooler, after market filter, moogoose full sytem no boxes striaght through, if that help you. :thumbs:
