Apexi Turbo Timer (wiring?)
Mighty_Mini
Go!Go!Auto
Hello again,
Just got an old Apexi Turbo Timer and will be fitting it in my mini (attempting to)
I need to find which wires are which..
I can get pictures if needed.
Only markings on the timer itself is "AT 9509-2056"
Wire colours are as follows;
Red,Green,Blue (into a block conncetor)
And
Black, White (On their own)
Cheers
Dave
A turbo timer works on these priciple wires i would imagine,
Ignition
Shut off switch ( handbrake switch)
Positive+
Negative-
So knowing this id try and find out which is which...
Carefully try running 12v+ throught it using black and white, and see what happens, But carefully.
A multimeter is a handy thing!! If no luck try and contact Apexi and ask for HELP!
Mark
ok, ive had it open... and ive also played around with ms-paint.
Can anyone figure this out? its the characters printed on the PCB by each colour.
PS- some of you may find these silly drawings amusing :p
index.php
