bmw 328 touring rolls alot.
littleT_23
Hi I was at pod this weekend and all went well. After seeing the pictures me mate took I noticed that the rear end of me touring rolls a lot. There is no knocking or strange noises coming from the back so was wondering if it was worth changing the anti roll bars.
First thoughts were fitting m3 bars;) cos of price but are they stiff enough or I just save for some eibachs or h&r
I've not looked yet but I'm looking into getting a second set of anti roll bars and jubilee clipping them to the stock ones to double them up. May not be able to due to space but I've seen it done loads of times before and it seems like a cheap way of keeping the car level.
Only if it's massively too soft. Softer springs and stiffer arbs makes for a very grippy car I've found. Just not so good on bumpy roads as you loose the suspensions independence a little.
If the sprigs are way too soft. Measure the inside diameter of the spring and get onto the rally design website and order some stiffer ones. Find out from here what rates people are using.
