BMW E24 635csi M30 Turbo Any Advice Appreciated
M60
Hi, I have a 635csi that I have been using as a track car
I've finally collected most of the bits needed in order to turbo the car. These include
RSI Manifold
TurboSmart Pro Gate 50
Nuke fuel rail
Nuke BOV
Nuke FPR
Emerald K3 and flying loom
Map sensor
Holset Hx35 with 12cm housing
Cometic 3mm MLS
Arp studs
B35 head
Bosch Green Giant 440cc injectors
Bpr7es/8es plugs
Clutch pressure plate and disc will be upgraded, still got to buy intercooler
I'm aiming for 350-450bhp with adjustable boost. If anybody has run an M30 with a similar setup I would appreciate any advice!
Many thanks
Sounds pretty good. What kind of advice are you looking for?
Cheers. I'm not sure, I just thought I'd ask if anybody had done a similar setup and whether they could give any feedback on how the car ran, any issues they ran into etc. Which clutches have people had the most success with and intercooler sizes/brands would be helpful.
Also, whether anyone has run an m30 on a turbo with a similar housing size? I was looking for instant spool and driveability, hence the 12cm but I understand it may choke the engine at higher revs. I've got a large wastegate just in case but the cam on these usually limits power over 5k anyway.
Thanks again
