NathanRiddle
Hi guys,
Just thought I would do a little thread of my build of my E36 Coupe.
I started the build a month ago and so far the modification list is as follows:
- E46 Lower Control Arm's w/Powerflex Bushes
- E36 Modified Hubs w/20mm Hub-Centric Spacers
- Medium Case Welded Diff, Soon To Be Small Case
- Fully Stripped
- TA Technix Coilovers
Work In Progress:
- Mounting x2 Sparco Bucket Seats w/Takata Harness'
- A/C Removed ( See Picture )
- Small Case Welded Differential
- Replacement E36 Tie Rod End's w/4mm Spacers
- Removal Of Viscous Fan & Installation Of x2 Manual Fans w/Switch To Dashboard
- Centre Console Control Plate ( Battery Cut Off, Ignition Switch, Fuel Pump Switch Etc Etc )
- HSD Coilovers w/Camber Adjusting Top Mounts
- Hydraulic Handbrake
- Straight Through Exhaust
- Roll Cage
I'm sure I have missed a few things off of the list! I will get some more updated photos of the build step by step and keep this thread updated as much as possible!
If anyone has anything that I may have missed off that they have done to improve the performance / handling etc please let me know!
Cheers,
Nathan Riddle
- Fully Stripped
Work In Progress:
- Roll Cage
Cheers,
Nathan Riddle
