bmw e36 seat mounts
MSC
Active Member
can you guys get them ? i had the low seat rail kit off you guys when i had my 200sx wondering if theres anything available for the e36 bmw
Hi there,
Afraid not, but E36 floor mountings are flat and symmetrical so it's easy to just bolt a generic sidemount bracket to the floor. :)
If you want to sit half out of the door. Cast your mind back Bon... What did you do?
Mounted it direct to the floor and aligned the off the shelf mounts I had to sit as far inboard as possible. Get the 3 peice jobbies with a rail and 2 bolt on mounts and you can do it.
So I did exactly what I just said above smart arse. ;) Resulted in the seat hard against the tunnel (with Sparco Evo 2 fatass seats)
Cheers yoof. I've only got the basic 2 side mount brackets so couldn't see what you meant.
