Full 1/4” Airlift kit for sale
Fits BMW e90 e91 e92 e93 e82 e88
Airlift V3 electronic management included, can operate pressures with your phone using the app, aswell as the controller.
440cc compressor, non return check valve, seamless tank, braided compressor hoses with push to fit, braided leader hoses, tank train, Airlift water trap etc.
Brand new Powerflex rear top mounts.
Also has backup Schraeder valve fitted incase anything happens to the compressor, you can use a normal tyre inflator.
One of the shocks has blown, and has rubbing on the lower sleeve. Replacements are £155.
Price is for as it is, or £2,000 if I supply a new rear shock.
You will require a reel of 1/4" air line, can be bought off eBay, caraudiosecurity or onlychargeddubs. I'd advise a rebuild before fitting, new o rings and front top mount bushes however there were no signs of these failing when fitted, just a precaution as they're off the car, you may aswell.
I can supply photos via WhatsApp or Facebook.
Collection only, can meet/deliver locally.
