boost nipple
MR.T
DRIFT RETARDED
do you guys sell any boost nipples? the ones that you fit in one of the rubber pipes, need to plumb my actuator in
Most LPG places would give you a self tapping nipple that will screw into the turbo outlet pipe. At the most they are a fiver
I took the one off the old t25, drilled and tapped a hole in the pipe off the t28r then screwed the nipple off the t25 into it.
Does the job and wont cost a penny!:thumbs:
there are so many i dont know where to t, i'm un sure if where it is is ok, its on the hot start vac that goes to back of inlet
Jay just use the original nipple off the t25 mate tap a hole into the hot side n run a feed from there mate
Ross
