Braided Clutch Line
Kato
Hi, Just wondering if you sell or can get hold of a braided clutch hose an R32 GTS-T. I'm running an uprated clutch and the extra pressure required to release it has seemed to have stressed the pipe and now i have developed a leak from where the fitting is pressed on the flexi pipe.
Cheers James
Hi James,
Yes we've got them in stock and ready to send out for next day delivery, £29.50 + 2.50 p&p. :)
If you can measure the length of your line WJ then I can tell you, but I'm 90% positive it'll be the same.
Will do.
Can you fit a 90 degree fitting to lin on the mastercilinder side ?
Because on the lhd cars, the fittings are on the "wrong" side, i.e. the fitting is on the left side, but the line needs to run to the right side of the car.
And one other thing, that braided line doesn't look like it connects straight to the slave cilinder, but to the rubber line coming off the slave cilinder ?
-WJ- said:
Will do.
can u do full replacements ?
