Braided turbo line ca18det
Aripug
Hi....i'm searching a braided turbo line kit to fit a gt2560R (t28R) on my ca18det
I've need of a plug and play kit...with the right oil adapter (gt2560r is a ball bearning turbo)
Your kit could be ok for me?
Thanks a lot
Sorry for my english
Hi, your English is good!
The braided lines will fit, the restrictor is in the oil feed on the turbo :)
Thanks a lot to had replied to me :)
So...if i will buy your kit...i can fit "plug and play" my gt2560R on my ca18det?
You will give to me the right oil fitment for my turbo, the bolts, washers?
Thanks again :)
Arian
Ciao!
The lines are arrived :D
But i've a problem...the oil feed banjo (the one in trhe red circle) can't fit on my gt2560R's oil feed hole.....do you have some different banjo?
Uploaded with ImageShack.us
Hi Ari,
Can you send photos of everything you've received in the kit to sales@driftworks.com ?? We've never had a problem before and as Kam says all the Garrett cores are the same, just need some info to work with. :) We'll get you the correct bits out as soon as we're sure you've got the wrong bits!
