Hello chaps,
Breaking for spares - Aristo 1999 JZS161
Its Pearl White, body is good condition, chassis is mint underneath, no rust!!
Only covered 74k miles and it shows.. (120kms)
Following goodies available..
2JZGTE VVTI - SOLD - Complete with ALL Auxhillaries, Turbos, Loom, ECU, FRONT SUMP, etc (One of the turbo's seals has gone)74k Miles - Very smooth running, no nasty noises, not stutters or anything bad.. Aux BeltTensioner is a little squeaky but nothing else wrong with it. Looks very clean inside rocker cover(badly looked after ones are all coked up). Engine has been removed with care, everything was unbolted rather than hacked off, you are buying just about every engine related component down to PAS High Pres line & Resevoir, Ecu with OEM box, pipes to heater matrix, OEM downpipe, gearbox bolts, air filter, etc..
I have a 2 and a half minute video of starting the car from cold this morning and letting it run, showing it starts first time, shows it does not smoke, and shows it does not knock, tap or bang.. Ask & I'll email it..
This is by far the cheapest priced 2jzgte online in the uk at the moment, priced to sell as I don't have the space to have it wedged up my arse for ages and I'm not greedy. A pair of turbos can be bought for as little as £100, but most people buying this will be putting a single turbo on it anyway... (A friend has a new HX40 forsale )
Transmission with Torque Converter £375 (74k miles)(Mkll Aristo Specific 4spd Tiptronic)(You know you should have spare )
Radiator - Standard, Good Condition, has Trans cooler built in etc £60
Radiator Fans - 2x Big badass fans that are considerably more powerful than even very expensive aftermarket fans.. Comes with Relays and most wiring - £60 pair with cowling.
Greddy Front Mount Intercooler Kit Sold (Proper Japanese High Quality hard pipe kit with 'GREDDY' & 'TRUST' in the casting)
All Pipes cleaned inside and out.. Intercooler flushed through with thinners then hot soapy water, for a long time..
Few dents, few bent fins, but it IS air tight. All silicone connectors and jubilly clips included.
Greddy Front Strut Brace £85
Genuine Factory Front Yellow Fog Lights £45
Genuine Factory Xenon Head Lights £225 (Left Side Light Looks Literally Brand New, car shows signs of minor crash on that side so makes sence to be new.. Right side all works fine, but has a cracked & repaired front bracket, still has a good rigid mounting with all it's other thousand bolts.. Iv cleaned and polished the Right side headlight so it looks nice and shiny and matches the newer Left light..)
Ideal to make your GS300 headlights awesome
GS430 Late Spec Sport Rear Lights SOLD
Blitz Nur Spec Exhaust back boxes (bolt straight on to original system) SOLD
KYB Aftermarket Shocks & Springs SOLD
Genuine Factory Wind Deflectors SOLD
Rolling Shell SOLD
Collection from Surrey
Delivery can be arranged at your cost.
Paypal fees are to be covered.
Few pictures..
Rolling Shell SOLD
Few pictures..
