bucket seat and rails...
96dennis96
wanted to fit my sparco corsa and pro2000 with bride FG-rails today and now there are at least 2problems...
1st it´s a fooking tight fit
2nd my seat is off centre to the steering wheel :wack: and way too close to the door. i dont think that i´ll be able to fit a cage in between...
certainly others must have had those probs, just couldnt find any solutions...
:confused:
mine's fine, doh!
you tried wiggling it on the rail without the bolts being tight?
Try rotating the rails 180 degrees so instead of pointing _l l_ they point l_ l_
or _l _l or l_ _l till you get a reasonable fit/position.
Did mine last night, it was a bastard and a half, but its perfect now.
astraboy.
astraboy.
Cool, which seat you get matey? Any pics of it in the Carlton? :)
dunno if rotating will work.
the seat´s supposed to sit between the rails to be as low as poss.
putting it on the rails would mean it´s about 2cm higher - it´s already too high for my liking. will be worse when i get the cage.
i´ll give it a try tomorrow...
heh, sorry dude :o
I am only down the road in Staines though, we should meet up, plenty of venues we can hone our technique on ;)
What you drive?
astraboy.
heh, you're not going to be happy that I bought mine from Marlow then. And for 1150 as well *runs away* :D
astraboy.
