CA18DET Braided Turbo Lines
KillboSlaggins
Active Member
Hi all,
I'm taking my turbo and manifold off my s13 soon as the bolts have come loose and they're impossible to get to thanks to f***ing locking tabs. May as well replace the oil/water lines while I'm there for some new braided jobbies but I can't seem to find anywhere that does a complete set. Driftworks have discontinued theirs and the only other place I can find is japspeed but they're £100 just for lines and washers which seems a bit steep.
Saw this set on ebay and thought it was good value, just not sure if anyone has had any experience with "Mamba" at all? https://www.ebay.co.uk/itm/Turbo-Oi...692376?hash=item3f9fc90a58:g:O2EAAOSw94Ba6muK
Any guidance would be appreciated
Cheers
Mamba stuff is fine, but that oil line has a 1mm restrictor which IIRC the standard journal bearing turbo doesn't want.
Might wanna check if that restricor is removable.
Okay thanks man good to know, and I thought the same with the restrictor so I googled a diagram which shows they do use a restrictor but different Ø depending on different turbos?
The images on ebay show them as a separate inserts to the hose I think but I'll take my hose off first and see what I currently have before ordering.
Cheers!
