CA18DET flywheel with SR20DET pressure plate?
Smurfenglubb
Hi, I've just bought a new flywheel from here to my CA18DET and I've noticed that it has an extra set of bolt holes. It has one set of holes with a diameter position at 268 mm, which is CA18DET original. AND one set of bolt holes that is positioned at 270 mm. in diameter. So the big question is what are the other holes for?! Is it designed for SR20DET pressure plates also? I really want an answer to this, since I don't have access to an SR20DET clutch to test with.
Greetings from Sweden. :wave:
Hi,
No it wont fit SR, the pressure plates are larger.
They are for other random Nissan engines, RB20DE and FJ spring to mind.
