Hi there, I just noticed this now as I was changing my rear brakes. The rear camber arms have been hitting the chassis, and worn a round dent into it. Is this normal? Is it just a case of grinding the lip away?
I also get this on the toe arms and the subframe mount. I've ground bits away but I still get it. I've seen pictures of bent arms (chavbo??? On sxoc iirc)
The only suggestion I can see is maybe to solidmount the subframe so it's alittle higher?
