centrebore reducer spacers
Robbs
FRANTIC
was wondering if you would be able to get/make me some 20 & 25mm hubcentric bolt on spacers to fit an e39 5x120 that reduce the centre bore down from the e39 74.1mm centrebore to the usual bmw 72.6mm ???
i'd want a pair of each, also how much would they be ?
thanks :dw: :thumbs:
What's your e-mail address?
I'll look into it and let you know prices, won't be a problem :)
cheers for the email Kam :thumbs:
will it make a difference in price if i also want the spacers to be conversion spacers 5x120-5x114.3 with centre bore reduction from 74.1 - whatever nissan is ???
:thumbs:
Conversion spacers would be more expensive due to needing studs & more machining work, rather than just being slip ons with longer bolts.
Kam emailed me a quote and up there in the OP i did say bolt on spacers, so was my quote for bolt on or slip on ? (i presume it was bolt on considering the price) so would it be the same for them to be conversion spacers as the work needed to make them would be the same its just 2 different pcds ????
Bolt on, slip on, same same when you are using wheel bolts.
Those conversion spacers would be £112.80 :)
