Cheap ae86
Status
Not open for further replies.
Talat
Hello all,
I currently have a 1986 Levin for sale. I have used it as a donor car for my other 86 but it would make an ideal project car for someone imo - spec is as follows:
- 127,000 Km's
- Power steering
- Electric windows
- FRP vented bonnet
- LSD
- Front fogs
- Zenki splitter
- Rear adjustable shocks
- Panhard rod
- Aftermarket cat-back exhaust
- Bride drivers bucket seat
- Front strut brace
- Carpet has been removed
Bad bits:
- The shell is solid but the bodywork could do with some tidying
- Passenger side front lower suspension arm will need replacing (I will include one in the sale)
The car is unregistered but will come with all paperwork to get it registered - can be seen and inspected on a ramp.
Please see pics below (note that aftermarket radiator has since been replaced with a standard item and rear strut brace has been removed):
http://i120.photobucket.com/albums/o172/JZX100/white86/front.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/rear1.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/DSCF0248.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/DSCF0246.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/1413-4007_CorollaLevin_20.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/1413-4007_CorollaLevin_19.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/1413-4007_CorollaLevin_18.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/1413-4007_CorollaLevin_11.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/1413-4007_CorollaLevin_05.jpg
http://i120.photobucket.com/albums/o172/JZX100/white86/1413-4007_CorollaLevin_02.jpg
Looking for £2k.
Cheers,
T.
Damn I knew I put this in too cheap :) I'm very busy with work at the moment so I will try and answer all PM's tomorrow. Basically the car won't be going anywhere until mid-week at the earliest since I need to arrange getting paperwork sent to my mechanic. Just a few things to add that I forgot to mention in the original ad and to answer some of the questions I've had via PM:
- Car is drivable around the yard but I wouldn't recommend someone coming to pick it up and trying to drive it away since that bottom suspension arm needs replacing.
- Brake pedal is soft - could be a case of them needing bleeding but I'm not going to throw resources at it trying to find out since it's cheap enough as it is.
- Needs no welding as far as I know - like I said, can be put on a ramp for inspection underneath.
- The drivers side front wheel is a 14" cross spoke - a matching wheel is included but it's damaged and I'm not sure if it can be repaired or not.
Cheers,
Talat.
Status
