Cheap TSW 17" 5x114.3 Alloys
Duke
Selling my old 17x7 TSW "Spyder" alloys. Offset isn't great and they are not the best looking wheels but all are straight and perfect for skids. £50 collected from Frome, Somerset.
Just found out that these are 'Spyders' with an offset of ET40. Also they are multi fitment, here's from the man himself:
TSW Man said:
The floating washers in the bolt holes make up the system called " Vari-fit ". They are moved to one of either 5 fitments to get the desired P.C.D. also known as stud pattern. Rotation of the vari - fit system can give you the following P.C.D's. 5x100,5x110,5x112,5x114.3 & 5x120.
Obviously you'll need some spigot rings to make sure they sit centre.
Are there any cracks on the wheels and do they all hold air well? How much does each wheel weigh so I can work out the courier charges and will you package them up if I do decide to buy.
No cracks, they hold air fine. I'll wrap them in cardboard/binbags if required. I'd estimate they weigh about 8kg each.
