Classic retro 1984 Honda Civic 1.5S
Swampy442
Active Member
With one too many projects on the go and cash needed to plough into my Do Luck Aristo the lovely little Civic has to go :(
Its a cracking litle motor, 1.5, 12 valve carb powerz under the bonnet means its no racer but it only weghs 560kg's so its quite perky. 104k miles on the clock and 4 owners from new.
Rear end has some eBay coil over convertors on which means its rock hard, front is standard torsion bars.
16" split rims running T1Rs give great grip but load up in corners, also included is a set of standard 13" steels.
The only bad point is theres rust on the front location points for the sun roof (can get pics if you like) and a hole about the size of a 10p peice centrally in front of the sun roof seal, bit of welding will sort it, and the paint on the passengers door is faded compared to the rest of the car.
MOT until 29/09/11, tax until 28/02/2011
No interior carpets (ight weight innit) but theres a roll of audio carpet included.
Car is located in Lincoln. Go on, get yourself some rerto cheap fun, dirt cheap to run/insure and turns alot of heads :) Cheers, Craig.
£650 ono. More pics and detail on eBay:- 1984 HONDA CIVIC 1.5S Retro on eBay (end time 07-Jan-11 13:52:50 GMT)
will pm you with my phone number mate, very intersted. its a lovely car
for some reason i can't pm you, would you be able to get me your number and arrange to have a look
