For Sale CLM BMW Steering angle Lock kit! Up to 70*.
Polostap
References from our top drivers in the UK:
Driftcup:
Drift Cutler
Frazer Jamieson BAM BAM
BDC:
Pro-am: Louis Lawrence
PRO: Ben Manuel
www.poperformance.co.uk
CLM BMW full lock kit e30, e36, e46!
A little bit extra about CLM BMW full lock kit.
It is a effect of two years experiments and work on front axle of BMW E36. This lock kit is made by CNC machines using laser cutting, turning, grinding, hardening metods. It can be used in BMW E30 or E46 too but dumpers have E36 style fixing (you will need e36 coilovers to the front. These are plug&play).
Main features:
- completly and permanently removed ackerman correction + additional correction for wild ackerman effects
- huge lock angle of 70 degrees (or even 75 degrees for your needs).
- divergence between front wheels not exceed 15 minutes at full lock (rise linear from 0)
- custom knuckles designed from scratch in CAD 3D environment, manufactured on modern machines by qualified engineers
- custom knuckles reduces bump-steering by recovering factory arm position in lowered cars (35 mm of correction)
- custom knuckles widen front axle for aditional 3 cm - so there's no need to use additional wheel spacers for wheel/tire to chassis clearance (& less weight)
- custom knuckles designed for using bigger and tougher E46 tie rods
- lower arms made of construction steel laser cutted on CNC Trumpf optic laser
- upper relocating plates made of high grade aluminium
- kit includes set of hardened screws and bolts, new hubs and bearings, rods and tie rods
This is the ONLY ONE kit on the market which is using OE BMW parts like bolts, rods and tie rods.
All that and full 2-years warranty and support for only £749!!
Order it today!
VAT invoice available.
#BDC #Britishdriftchampionship #IDC #BMW #Lockkit #drift #driftcup
