Coilover Springs
Gn0m4
Hey guys,
Do you sell these separately? I'm after some 11k springs for the front and 7k for the rear of my Mx5 Mk1 (HSD dualtech)
Are the fronts an backs the same size? I would like to try my current fronts (9k) on the back and the 11's on the front.
Would i need re-valve dampers?
kind regards,
Carlos QuinT
Hi There,
Thanks for the message, we can do you 12kg for the front and 7kg for the rear. You may have issues with the rear springs, how low is your car?
Rich
Hi Rich,
that´s last photo i took of my car. Now is under restoration and modifications.
I will go a bit higher cause i will mount 15x9 ET0 over 225/45 R888 (instead 15x8 ET25 over 195/50 RSR) and i´m scared to scratch fender flares and rub structural chassis.
I will change sway bars but i don´t know what to do with springs... cause in hard brakings and turns (much much harder now with wilwood brakes, widebody and wider/better tyres) i think only sway isn´t enough to keep tyres away from interior frame of the car.
You can see my lowered car sank with RSR tyres and stock sway bars
