Hello
I'm not really into the drifting scene but thought that someone here could help. I am building a Lamborghini kit car and I have chosen a Cadillac DTS as my powertrain. Basically because its a V8 and transaxle combo that I can just move from the front of the car to the rear. Not building a track car I want it reliable. Anyway to my question; Because I have moved the front suspension cradle ect, to the rear of my kit build I have no E-brake. Obviously I need one and as I was searching Summit racing they have a whole seperate caliper and master cylinder that I can install for like $2000. Yea thats a bit much so as I dug in further I noticed that for about $42 I can buy a master cylinder that you install inline to the rear brakes and it applies pressure to the existing calipers for a drift car. HERE
RYANSTAR Hydraulic Handbrake Adjustable Ebrake Long Lever Handle Fit for Drift Track Rally Racing Master Cylinder 0.75, E Brake Racing Emergency Brake Vertical Position Ergonomic Handle & Anti-Slip (amazon.com)
What I want to do is use my old E-brake lever that has a ratcheting apply and button release to actuate this drift cylinder. So wondering if anyone has used these and will it hold pressure and work as an E-brake.
I dont see this being any different than the electronic E-brakes that use a solenoid to apply pressure.
I know it will require some fabrication to change up the pull arm but assuming thats all done can a drift lever in a locked position hold the car?
Sorry I know this was long and maybe more detail than you needed but wanted to avoid all the questions about why.
Anyones input would be certainly appreciated.. Thanks
