cressida coilovers
If your car already has coilovers with topmounts then you have options for making one of our CS2 or HSD kits work, if it doesn't then you need to look to the US.
Looked into coilovers but they are proving tough to source. The car is currently running no front springs with what looks like standard shocks? Just made some rear shocks using e46 dampers and it has chopped rear springs. Apparently the rear springs can be changed for s14 rears?? Can you give me any pointers on front lowering springs and rears? Don't want to heighten it too much as the look joycey has made looks good :)
Are you sure it's an 81 chassis? Just found Dan's thread, it's a 1981 Cressida.
No option for lowering springs really, making some coilovers work is the best option. Wouldn't be hard to do but would require mechanical knowhow.
