Firstly in light of a recent R32 for sale thread i hope im not slated for describing this as a well known car with quite a bit of history as in this case i assume its true
I dont really want to have to do this but as ive only just got to the point where the car is pretty much sorted and i can actually drive it, after months of anguish trying to get parts etc . my financial situation is somewhat crap for want of a better word though and sadly if i cant find some money from somewhere then this is going to have to be
a thread containing the majority of the work that has been carried out is here
http://www.driftworks.com/forum/projects-builds/36987-r32-re-birth.html
and this is the origional for sale thread when i bought it off Bonbon
http://www.driftworks.com/forum/dri...-my-d1gb-final-winning-r32-skyline-gts-t.html
When i first bought the car i had it mapped and it made 365.6bhp and 300lbft at 1.5bar of boost, i had the car mapped last week and its now making 337.9bhp and 300lbft at 1.2bar and its made a hell of a lot earlier. on my project thread is a graph showing dyno runs at the same place but with the old engine and the new engine.
The car is very fast as it is, but if i were to keep it or what i would advise the new owner does is fit an AVCR or any proper boost controller for that matter, fit the larger injectors and get it mapped with the ECU not the SAFC (the ecu is now already socketed so a blank eprom chip can be fitted in minutes to be able to map ingnition and fuelling) and with this done and running 1.5 bar im certain the car will easily see over 400bhp and loads more torque
The car has recently been MOT'd and think it has just over 11months MOT left, it sailed through the MOT with no problems at all (after the windscreen was replaced at great cost that is) the only problems were 2 new wipers needed, a headlight bulb and a new drivers side indicator. the wipers and bulb were sorted about 30mins after the MOT but i still havent got round to buying a new indicator yet , im not 100% certain when the tax runs out but i think its end of august.
the spec list is as follows
ENGINE = RB20DET
CP forged pistons
ARP head stud and nut kit
Tomei 1.6mm metal headgasket
new bearings, gaskets, pumps, belts etc
HKS GT2835 turbo newly rebuilt by owen developments
tial 38mm external wastegate
heat wrapped manifold and downpipe with t25flange
HKS exhaust with silencers removed
screamer pipe and spare pipe to route wastegate back into exhaust if needed
370cc injectors and spare set of 444cc injectors
walbro fuel pump
Z32 AFM
Blitz air filter
nismo adjustable FPR
thermostatic oil cooler kit
mitsubishi evo 8 intercooler
driftworks wasted spark remote coil pack kit
Transmission
Uprated semi-metallic clutch disc with uprated GTR pressure plate.
Uprated gearbox mounts.
Freshly replaced gearbox with very very low mileage unit.
low mileage s14 lsd
Wheels and tyres
Orange Rota GTR 18x9.5 et30 all round
Falken 452 265's rear (less than 1000miles)
Kuhmo track tyres at the front
Suspension/Brakes
Brakes up to the buyer really, it currently has K-sport 356mm 8pots but will most likely sell with 280mm discs and 4pots for a lower price
ferrodo DS2500 pads
braided brake lines
K-sport coilovers
k-sport rear camber arms, rear toe arms, rear tc arms, and front tc arms
cusco front camber arms
tein tie rods and rod ends
solid alluminium subframe bushes
solid steering column bush
steering rack poly bushes
lower arm polybushes
safety devices 7point roll cage with removable door bars
front strut brace
s14 rear subframe
all hicas stuff removed
increased steering lock
Bodywork
URAS bodykit including =
front bumper
rear bumper
sideskirts
D-MAX 50mm wider rear arches
Veilside rear spoiler
Lots of zipties stickers and battle scars
brand new windscreen costing over 1000 pound
Interior
Recaro SPG bucket seat
OMP passenger bucket sreat
Sparco steering wheel
saftey devices harnesses
K-sport snap off steering wheel boss
HKS turbo timer
Apexi SAFC2
oil temp gauge
oil pressure gauge
water temp gauge
nismo boost gauge
spin turn handbrake button
mechancal fire extinguisher system
battery cut off with pull cord
stripped out for less weight
There are quite a lot of spare to go with the car aswell including =
fully rebuilt cylinder head
crank + standard rods and pistons
block with all hoses and sump etc
inlet manifold
alternator
444cc injectors on painted fuel rail
spare used tomei HG
pair of new Uras side skirts
uras rear bumber (currently located at bonbons house )
front wing to replace damaged one
standard front bumper
drivers side wing mirror
and im sure there are quite a few other bits lying around too
below are a couple of vids with the car in action last year.
YouTube - final 1 przejazd
YouTube - final 2 przejazd
YouTube - D1GB / EDC DRIFT SILVERSTONE Round 4
below are a few of my favorite pics of the car in my possesion and there are many others on the two threads i linked to at the top of the page
as you can see the bodywork isnt the best and i would hardly describe it as concourse but having said that the sturcture of the car is solid with little to no rust on the sill chassis rails etc, and the dent in the roof will push out from the inside, it comes with a new drivers side wing ready to fit and there was a bonnet going for 20pound recently so a new one of them could easily be sourced then with a quick lick of paint your ready to go.
i paid 6000 pound for the car in january (and somebody else had offered 7000 pound for it) and with just a quick calculation not including the new suspension and brakes ive easily spent over 3000pound on it. the cost of the brand new suspension parts going with the car aswell is worth just over another 1000pound.
i know you dont tend to make your money back on parts youve bought when selling cars but taking into account it owes me over 10,000 pound and has a failry large spares pack lol, im going to put the car up for 8000 pound as it is and see what happens , it may sound a lot for a R32 GTST but if you think how much it would cost to build a car to the above spec and how many R32's there are in this country that are wide arched, caged and ready to race with an easy and reliable power output of over 400bhp (with an extra 250-500pound spent that is on mapping and boost control)
p.s. i will be willing to knock a bit off the price if the somebody wants to buy it without the wheels recaro seat and steering wheel, i have standard parts to replace these with if neccassary or you already have your own parts you want to use
p.p.s i tend to forget stuff when writing threads like this so will most likely be along to edit this shortly
p.p.p.s i knew it already had to edit the thread with detail on the bodywork, and also a quick mention about the ride height, i know it shamefully high in the last picture but that was only as i was keeping it high so i didnt damage the bumper going on to the dyno again.
cheers
james
ENGINE = RB20DET
CP forged pistons
walbro fuel pump
Z32 AFM
Blitz air filter
Transmission
low mileage s14 lsd
Wheels and tyres
Suspension/Brakes
ferrodo DS2500 pads
braided brake lines
K-sport coilovers
front strut brace
s14 rear subframe
Bodywork
front bumper
rear bumper
sideskirts
Interior
HKS turbo timer
Apexi SAFC2
oil temp gauge
oil pressure gauge
water temp gauge
nismo boost gauge
inlet manifold
alternator
spare used tomei HG
cheers
james
