P pharmed Member May 16, 2015 #1 Need one for a auto gearbox, as big as possible. Loads on the bay but which do people recommend on here?
S Swampy442 Active Member May 16, 2015 #2 A cooler is a cooler, if in doubt go Mocal. Also why as big as poss? What power are you running?
Ruishy1 Active Member May 16, 2015 #3 Shim your accumulators, lessens heat build up between gearchanges.
P pharmed Member May 16, 2015 #4 Accumulators shimmed (8mm) and valve body pressure turned up. Swampy - I'd like to play it safe and future proof for up to 500 odd horses Last edited: May 16, 2015
