BMW 328i e36 coupe
Genuine 328i
Black
MOT: mid 2018 from memory
Sadly selling my drift car as it never gets used anymore, just sits around being wasted. Overall brilliant drift car, crazy amounts of lock and over the years I’ve had it I’ve never had an issue. Purchased as a standard e36 and all modifications done by either myself, AJ Custohms. Always well looked after and serviced. As expected with a drift car the exterior isn’t the best but still looks decent with a clean up. Few dinks and scratches, no major dents.
Spec:
OBP hydro handbrake with .625. Fitted properly, welded in and fitted by AJ Customs
Sparco pro 2000 drivers seat on custom made moveable rail by AJ Customs
Genuine OMP drivers harness
Cobauru passenger seat with driftworks side mount rails
Sparco passenger harness
Interior fire extinguisher
AJ Customs bolt in half cage
Extreme offset front wheels 16inch, Toyo proxxes tyres
Drift rear wheels with x2 spares
Stainless steel power flow exhaust
Small case low ratio diff professionally plated and welded by AJ Customs
HSD Coilovers, damper and camber adjustable
E46 lower arms and poly bushes with new lollipops
Modified hubs by AJ Customs
Single flywheel conversion with brand new starter motor and clutch to match
Bad bits:
Cracked screen, been like this for ages and never got any worse
Front bumper has seen better days
Sometimes randomly pops out of 4th gear but very rarely and never while drifting, it’s always done this and never caused an issue. I do however have a spare 328 gearbox to go with the car anyway for if problem was to ever get worse
£2500
