Defi Gauges
GTSr32
Hello was wondering do the defi gauges come with all the senders.
I.E. dose the boost gauge come with a boost sender? ect?:wack:
Also the Link - Display
If i wanted Oil temp, Water temp, Fuel pressure, what do i need to get ?
getting confused with all these harrness and dasy chains ect
gauges (like this) come with the sender
display comes with no sender so you'll need 2 temp senders (oil,water) and a pressure sender in additon (senders only aren't listed in the shop but guess they can get them...)
either way you'll need the controlunit as that's where the senders plug in, from there you have one cable leading to display/gauge and then directly on to other gauges ;)
hope that helps
