Davie,
if you've already got the controller, you just need the gauge which comes with the wiring and sensor.
Do you know if your sandwich plate has 2 takeoffs for gauges? If so, you can fit the pressure sensor there, if not, normal practice is to T off the standard oil pressure sender on the engine block (we can supply T pieces for this)
