caprizi
Alright guys I had the intake manifold off my S14 for some work I was doing. When i put it ll back together I stupidly mixed up the waterlines with attach underneath for the vac lines and started the car not realising this.I started the car and it ran a bit rumbly for the first 30 seconds or so then started to shoot white smoke/steam from the exhaust. At this point I realised what was going on and killed it immediately.
I pulled the plugs and fuel pump fuse and cranked it straight away in an effort to remove that water from the cylinders. Not much actually came out and i removes the rest with a absorbent material on the end of a stick through the sparkplug hole.
I have had to leave the car over night but plan to change the oil tomorrow as a precaution and try start her up after.
My question what is the likelihood this has done lasting damage? and is there anything else i should do as well as just changing oil ?
Cheers lads.
Cheers lads.
