Hello, i'm from germany and currently building an e36 missile. I got some special questions on the E36 diff (Lsd, 188) that no one was able to answer me yet..
1. And most important:
How much material can i take off the lsd cover?
I read an instruction for building a 45% diff from the original 25%. There are 2 opportunities, 1 is cutting other angles into the tension rings, 2 is using 4 laminate packs instead of 2. But in that case, i read i could not use the cup springs anymore because theres not enough space inside the lsd "body". (No cup springs= no preload = not good for drifting) so where's the problem with taking 5mm of material off the cover, to make more space, so i could still use the cup springs? I'm especially looking for users who have already done something like this..
2. Question is more simple: How do i set the right clearance for the taper roller bearings (propeller shaft side)?
Thanks, hope someone is into stuff like that and can help me
