Dimensions & Spring Rates for Coilovers (jzz30 & jza80)
PDE
I'm planning a small project and was thinking about using a set of your cs1 coilovers (nice price:thumbs:), but I need some dimensions/data to be sure that they will "fit"....
I would like to know:
* Length fully "expanded"
* Spring diameter
* Spring rates
for the jzz30 and jza80 coilovers...
A big thank you in advance!
Mikael
Hi PDE!
Sorry for missing this. :) What measurement do you want, between which points??? Top of the topmount to the bush at the bottom?
18k/10k spring rates, 65mm ID, 90mm OD springs. :)
Hi PDE!
Yep! Top of the topmount to the bush at the bottom is what I'm interested in...
...Oh, and thanks for the reply:thumbs:
hope you don't mind me barging in for one quick question, what size internal diameter are S13 CS1 springs? 2.25? and 8 inches length? same front and rear?
For the CS1 and HSD coilovers, they're 65mm ID, 200mm long for both front and rear
