maxitoman007
found a good deal on a knock off Bee*R type B rev limiter. Has large loops. Shiny wire casing. Odd print under knobs. But it has the right offset square bolt pattern... so idk. Has anyone successfully run a knock off?
Oh, why is that? for only $70 USD makes me wonder if its worth the risk.Just looked at this guys other items on eBay. I wouldn't touch it with a barge pole
No I do not, I'm currently working on a 1987 Volvo 740 Turbo with some mods.Do you have an ECU currently with an adjustable rev limit?
My ecu is non chippable, Lh 2.2. Already have a hoodpipe.Redblocks have an ak47 limiter stock, no need for that shit.
Spend your money on something worthwhile like chips and a 3" exhaust
T3/T4 60AR cold side 63AR hot sideCould upgrade to 2.4 but huge effort for little gains.
What turbo you running?
Not trying to raise it just have a secondary lower one. I guess I could just use a regular rev limiter and just set it under the stock limit. But I don't think those will have a gain adjustmentI don't think a Bee*R will enable you to raise your rev limit.
If you have a stock limit in place it will stay in place.
