jimycrimson
Hi all,
I'm building a simple CA18DET, just for track, I removed:
- Oil/water thermo and replace by aftermarket oil cooler with thermo.
- IAC valve (IDLE managed with throttle bolt)
- No water lines for intake manifold, I'm using termal gaskets just leave the turbo water line.
So, the question is here:
I wanna remove the PCV valve, so, I think I've to conect the hoses from valve cover to catch tank, tap the PCV and the plug from intake.
It's right?
Regards
It's right?
Regards
